11 years agoVIP Scaler II Megacore: Garbage at bottom of image
Hi, I'm trying to upscale a 1024x768 image to 1280x1024 using the Altera VIP Scaler II IP Core. I have set up the Clocked Video Input IP core to receive the image signal, then the image is up...
11 years agobktemp - Good idea to plug in the test pattern generator and verify that the pipeline functions correctly without the CVI. Based on everything you've described here I am stumped as to what the problem is. If you figure is out please post back here and let us know.
Good luck!
