11 years agoVIP Scaler II Megacore: Garbage at bottom of image
Hi, I'm trying to upscale a 1024x768 image to 1280x1024 using the Altera VIP Scaler II IP Core. I have set up the Clocked Video Input IP core to receive the image signal, then the image is up...
11 years agoI have not used the clocked video input or output cores so I'm not sure how they work. The easiest way to figure this out may be to simulate the whole pipeline so you can see exactly what's happening. Either that or use SignalTap.
On a different topic, are you aware that the aspect ratio of your input and output video are not the same? 1024/768 = 4/3 whereas 1280/1024 = 5/4. This means your images are being distorted slightly (compressed horizontally I think). That may not matter in your application, but if it does then you need to change your output resolution to something like 1280x960.
