11 years agoVIP Scaler II Megacore: Garbage at bottom of image
Hi, I'm trying to upscale a 1024x768 image to 1280x1024 using the Altera VIP Scaler II IP Core. I have set up the Clocked Video Input IP core to receive the image signal, then the image is up...
11 years agoThank you for your answer!
The main problem is probably my unterstanding of how the Clocked Video Output IP core exactly works. How do I change the output-input timing relation? Since the input timing is fixed, I can only change the output timing. And since I do not have a framebuffer, the output framerate must match the input framerate exactly. My unterstanding from the VIP Suite User Guide is the following: As soon as a new input frame starts, the scaler starts upscaling the video data delivered by the CVI core. When the fifo at the CVO core has reached the set threshold, output of the active image data starts. This provides some synchronization to lock both framerates, but it violates the set timing values for the output if the framerates do not match otherwise. Is this correct or did I miss an important point?
