16 years agoVIP Scaler and Clipper usage
Hi, I've tested the following three design flows in SOPC builder and they work: 1. CVI(1920x1080@60Hz) -> Clipper(1680x1050) -> FrameBuffer ->CVO(1680x1050) 2. CVI(1920x1080@60Hz) -> Scaler...
11 years agoHi,
you have to be aware that the incoming stream (at Clocked Video Input) is a stream without backpreassure, so if you miss even one data-packet you will loose the sync of the date and have to re-sync again, the same at the output side. If there is no data to transmit for even one clock cycle, the monitor will loose the sync...
