16 years agoVIP Scaler and Clipper usage
Hi, I've tested the following three design flows in SOPC builder and they work: 1. CVI(1920x1080@60Hz) -> Clipper(1680x1050) -> FrameBuffer ->CVO(1680x1050) 2. CVI(1920x1080@60Hz) -> Scaler...
16 years agoSince this is an upscale, I would guess that the scaler is applying quite a lot back-pressure on the clipper which in turns applies back-pressure on your input and overflows it. Maybe you could try putting the frame buffer between the clipper and the scaler?
