10 years agoVIP Problem with 85Hz Resolutions Frame Rate
Hi! I am relatively new to Altera and Nios2 and I am now developping a system with an ArriaV which objective is to transform VGA signal in LVDS with the ADC TVP7002. For the moment I am able to...
10 years agoHi! Sorry for the Image Size, the following are bigger:
http://www.alteraforum.com/forum/attachment.php?attachmentid=11849&stc=1 http://www.alteraforum.com/forum/attachment.php?attachmentid=11850&stc=1 Anyway the CVO is meant to work at 60Hz because of the Screen refresh rate (And it does with small NATIVE resolutions). The Frame Buffer is the IP responsible of changing the Frame Rate from 85Hz to 60Hz.
