10 years agoVIP Problem with 85Hz Resolutions Frame Rate
Hi! I am relatively new to Altera and Nios2 and I am now developping a system with an ArriaV which objective is to transform VGA signal in LVDS with the ADC TVP7002. For the moment I am able to...
10 years agoI can't see nothing on this picture, could you please make a large screenshot? In any case, you are using an external clock signal for CVO, check that its frequency is sufficient to transfer 1920x1200 pixels at 85 frames per second.
