15 years agoVIP mixer debugging
I am have an alpha blending mixer using a solid color test pattern for layer 0 as output when my normal image/video sources are not available. I can run the system with both of the sensors att...
15 years agoThere is no additional requirement. Make sure all foreground layers are deactivated (with 0, NOT with 2) before you start the mixer and it should work.
You could enable the slave interface of the CVIs blocks and keep them on the off position to ensure that nothing goes through the system.
