13 years agoVIP issue
Hi, I'm working on a design based on VIP suite, in which I have a video signal coming from a camera that is mixed with a video signal from the VIP test pattern generator, using VIP Alpha blending mixer: everything works. If I replaced the VIP test pattern generator with a VIP module designed by myself, nothing works: the alpha blending mixer seems to detect a wrong frame format and the layer 1 is not visualized well. Using signal tap I can verify that the Avalon video streaming protocol of my module works fine. My question is: can I have a sample design for the source avalon video streaming to compare it with my own? I can attach the VHDL code if someone is interested
Thanx in advance2 Replies
please attach some code and the signaltapdata from your control-packet
--- Quote Start --- please attach some code and the signaltapdata from your control-packet --- Quote End --- That's my state machine: process (av_reset,av_clk,state_streaming,av_st_ready,go_bit,width_val,height_val,blend_val,width_count,height_count) begin if (av_reset = '1') or (go_bit = '0') then --if (av_reset = '1') then width_count <= "0000000000000000"; height_count <= "0000000000000000"; av_st_data_sig <= X"0000"; av_st_valid_sig <= '0'; av_st_start_pack_sig <= '0'; av_st_end_pack_sig <= '0'; state_streaming <= SEND_ID_CONTROL_PACK; elsif (rising_edge(av_clk)) then case state_streaming is when SEND_ID_CONTROL_PACK => av_st_data_sig <= X"00FF"; av_st_end_pack_sig <= '0'; if (av_st_ready = '1') then av_st_start_pack_sig <= '1'; av_st_valid_sig <= '1'; state_streaming <= SEND_CONTROL_1PACK; else av_st_start_pack_sig <= '0'; av_st_valid_sig <= '0'; state_streaming <= SEND_ID_CONTROL_PACK; end if; when SEND_CONTROL_1PACK => av_st_data_sig <= "0000" & width_val_std(11 downto 8) & "0000" & width_val_std(15 downto 12); av_st_start_pack_sig <= '0'; if (av_st_ready = '1') then av_st_valid_sig <= '1'; state_streaming <= SEND_CONTROL_2PACK; else av_st_valid_sig <= '0'; state_streaming <= SEND_CONTROL_1PACK; end if; when SEND_CONTROL_2PACK => av_st_data_sig <= "0000" & width_val_std(3 downto 0) & "0000" & width_val_std(7 downto 4); av_st_start_pack_sig <= '0'; if (av_st_ready = '1') then av_st_valid_sig <= '1'; state_streaming <= SEND_CONTROL_3PACK; else av_st_valid_sig <= '0'; state_streaming <= SEND_CONTROL_2PACK; end if; when SEND_CONTROL_3PACK => av_st_data_sig <= "0000" & height_val_std(11 downto 8) & "0000" & height_val_std(15 downto 12); av_st_start_pack_sig <= '0'; if (av_st_ready = '1') then av_st_valid_sig <= '1'; state_streaming <= SEND_CONTROL_4PACK; else av_st_valid_sig <= '0'; state_streaming <= SEND_CONTROL_3PACK; end if; when SEND_CONTROL_4PACK => av_st_data_sig <= "0000" & height_val_std(3 downto 0) & "0000" & height_val_std(7 downto 4) ; av_st_start_pack_sig <= '0'; if (av_st_ready = '1') then av_st_valid_sig <= '1'; state_streaming <= SEND_CONTROL_5PACK; else av_st_valid_sig <= '0'; state_streaming <= SEND_CONTROL_4PACK; end if; when SEND_CONTROL_5PACK => --av_st_data_sig <= X"000" & "0011"; av_st_data_sig <= X"000" & "0010"; av_st_start_pack_sig <= '0'; if (av_st_ready = '1') then av_st_valid_sig <= '1'; av_st_end_pack_sig <= '1'; --state_streaming <= SEND_ID_VIDEO_PACK; state_streaming <= WAIT1CYCLE; else av_st_valid_sig <= '0'; av_st_end_pack_sig <= '0'; state_streaming <= SEND_CONTROL_5PACK; end if; when WAIT1CYCLE => av_st_start_pack_sig <= '0'; av_st_valid_sig <= '0'; av_st_end_pack_sig <= '0'; state_streaming <= SEND_ID_VIDEO_PACK; when SEND_ID_VIDEO_PACK => av_st_data_sig <= X"0000"; av_st_end_pack_sig <= '0'; --if (av_st_ready = '1') and (go_bit = '1') then if (av_st_ready = '1') then av_st_start_pack_sig <= '1'; av_st_valid_sig <= '1'; state_streaming <= SEND_VIDEO_PACK; else av_st_start_pack_sig <= '0'; av_st_valid_sig <= '0'; state_streaming <= SEND_ID_VIDEO_PACK; end if; when SEND_VIDEO_PACK => av_st_data_sig <= X"1080"; --è il nero av_st_start_pack_sig <= '0'; if (av_st_ready = '1') then width_count <= width_count + 1; av_st_valid_sig <= '1'; else width_count <= width_count; av_st_valid_sig <= '0'; end if; if ((width_count = (width_val - 1) ) and (height_count = (height_val - 1))) then av_st_end_pack_sig <= '1'; else av_st_end_pack_sig <= '0'; end if; if ((width_count = (width_val - 1) ) and (av_st_ready = '1')) then state_streaming <= CHECK_END_FRAME; else state_streaming <= SEND_VIDEO_PACK; end if; when CHECK_END_FRAME => width_count <= "0000000000000000"; av_st_valid_sig <= '0'; av_st_start_pack_sig <= '0'; av_st_end_pack_sig <= '0'; if (height_count = (height_val - 1)) then --FRAME TERMINATO height_count <= "0000000000000000"; state_streaming <= SEND_ID_CONTROL_PACK; else height_count <= height_count + 1; state_streaming <= SEND_VIDEO_PACK; end if; when others => state_streaming <= SEND_ID_CONTROL_PACK; end case; end if; end process;
