15 years agoVIP Gamma Corrector
Hi, I'm trying to find out what the VIP Gamma Corrector really does. In the application note to the UDX4 High Definition Reference Design (an627.pdf) the Gamma Corrector is used to conver...
15 years agoHi.
add/subtract I just meant if you are e.g. 2.22 gamma and want to add 0.1 for example then you would replace the values in the LUT:s based on calculations in non-linear space..otherwise you would not reach the correct result. It might be hard to find IP that does degamma and regamma functions.. the first part exp2.22 is trivial with lut:s but coming back down is tricky. I ended up spending a lot of time getting it right and had to do it from scratch since no ip was available - at least at the time.
