13 years agoVIP Frame Reader
Hello, I'm trying to read a single frame from the RAM using the VIP_Frame_Reader and NIOS2. I know the frame reader creates an interrupt each time it finish of read one frame but I don´t know h...
13 years agoHello, after read a lot of information about Nios 2 and fpgas, my project is almost finished but I still having problems with the FrameReader.
My project takes a frame from an Avalon ST video and stores it in ddr memory, after that one custom instruction perform a some modifications over the frame in memory and finally the FrameReader should read the frame from memory and give it to one Clocked Video Output connected to NEEK LCD. The frame is correctly stored in memory but when I try to show it in the LCD, the frame is showed for a moment and after that I got a black-screen. May anyone help me?. The FrameReader video output is connected directly (without any buffer) to the Clocked Video Output and the initialization code is: // Frame Select
IOWR(ALT_VIP_VFR_0_BASE, 3, 0);
// Frame 0 Base Address
IOWR(ALT_VIP_VFR_0_BASE, 4, &P);
// Frame 0 Words
IOWR(ALT_VIP_VFR_0_BASE, 5, 800*480);
// Frame 0 Single Cycle Color Patterns
IOWR(ALT_VIP_VFR_0_BASE, 6, 800*480);
// Frame 0 Width
IOWR(ALT_VIP_VFR_0_BASE, 8, 800);
// Frame 0 Height
IOWR(ALT_VIP_VFR_0_BASE, 9, 480);
// Frame 0 Interlaced
IOWR(ALT_VIP_VFR_0_BASE, 10, 3);
// start Frame Reader
IOWR(ALT_VIP_VFR_0_BASE, 0, 1);
