13 years agoVIP Frame Reader
Hello, I'm trying to read a single frame from the RAM using the VIP_Frame_Reader and NIOS2. I know the frame reader creates an interrupt each time it finish of read one frame but I don´t know h...
13 years agoThank you, I was checking this example and I find the way to get the interrupts.
Now I have other problem with this module. After stop the module, if I make any modification in the memory and I try to start the module again the output image becomes corrupted. (I'm sure in the memory the image is correct).
