10 years agoVIP Frame_Reader, Clocked Video IP Spec's
Hi Guys,
I have a question regarding the Frame-Reader and the Clock Video IP spec’s:- What do they mean by the Maximum Image Width and Height? Does that mean active (visible) plus inactive (sync, blanking, ect.)?
- What do they mean by Active pixels/Lines (in the case of the Clocked-Output IP) does that include only visible pixels/lines?
It is for both questions:
Only ACTIVE Pixels/Lines are meant by the IPs. Normally the Clocked-Video-Input cuts the blanking, so that you have only active pixel in the pipeline. If you have go pass another "standard-video-route" the Clocked-Video-Output inserts the blanking again... - Altera_Forum
Thank you very much !!!
