13 years agoVIP Frame Buffer Locks
Periodically, especially immediately following a Reset to my VIP system, one or the other of the 2 independent frame-buffers hangs up. I have SignalTap on the DoutValid and DoutReady signals througho...
13 years agoYeah, probing the guts of the VIP framebuffer is kind of a pain.
You could write your own frame buffer. It just needs a memory mapped master read port, mapped master write port, streaming VIP in, streaming VIP out, and a simple state machine to control the read and write pointers as video comes into the block. It should only take a couple of days to write and test if you are familiar with VIP and Avalon. Then you wouldn't have to use the Altera one anymore. I have written my own versions of a lot of blocks in the VIP family because of the same problem that you are having now. There is no good way to debug them when they don't work as advertised. Also I have found that when I wrote my own VIP block, it used substantially fewer resources compared to the Altera one.
