13 years agoVIP Frame Buffer Locks
Periodically, especially immediately following a Reset to my VIP system, one or the other of the 2 independent frame-buffers hangs up. I have SignalTap on the DoutValid and DoutReady signals througho...
13 years agoDo you mean VIP control packets?
I insert my control packets between each VIP frame. This might be your problem. It might also be possible that your video pipeline is not completely resetting correctly. You could write a little VIP "watchdog" block on the input or output of the framebuffer that could assert a system wide reset if doutValid is not asserted for a long time. You might also want to signal tap the guts of the framebuffer and see if there is anything that is obviously locking up.
