15 years agovip_example_design_3c120 design as in AN 427
Hi Can anyone post please the original vip_example_design_3c120 design as mentioned in the AN 427 document.Or give me a link to get the example design for the ALTERA
15 years agoHi,
Which board are you trying.The DVI or the Quad Video? Mind it both has different pin config and are totally different in their approach.If you have read the Doc this vip example requires both the inputs from DVI and the Quad video.Are you sure that you both the cards are connected in proper slots.Because for me they were connected in opposite slots.Check from the hardware board document u have got.Verify all your hardware first. If you have individually checked both the quad and DVI boards to run with examples then its good.Else I prefer u try them individually and then both together. The example I suggested is only for DVI.There is also example for quad video
