15 years agovip_example_design_3c120 design as in AN 427
Hi Can anyone post please the original vip_example_design_3c120 design as mentioned in the AN 427 document.Or give me a link to get the example design for the ALTERA
15 years agoHey
Do u have the daughter video card from bitec?U can try the code from bitec I have verified and it is working. Try to download the J8.sof of this example DVI 1080P Loop-through (Beta) The link is http://www.bitec.ltd.uk/ciii_video_dev_kit.html You may have to check the settings of the monitor also and select the DVI monitor.If you have a graphics card it will give u an option to choose the multiple monitor.Choose the correct moitor and set the refresh rate to 54 or 56 .And also the correct image format of DVI
