15 years agovip_example_design_3c120 design as in AN 427
Hi
Can anyone post please the original vip_example_design_3c120 design as mentioned in the AN 427 document.Or give me a link to get the example design for the ALTERA30 Replies
You can find everything from here
ftp://ftp.altera.com/outgoing/devkit - Altera_Forum
click the Download button on this page:
http://www.altera.com/support/refdesigns/sys-sol/broadcast/ref-post-processing.html - Altera_Forum
I using the Altera cyclone III EPC3C120 Development board connected by HSMC interfaces to Bitec HSMC quad video and DVI daughtercards.
The kit refers to AN 427 VIP sample design and asks it to download from the ALTERA site. The name of the file is vip_example_design_3c120_<version>.But I cannot find this file on the website of Altera to start with the kit. I tried to run the sample code but i got these errors. Error: Top-level design entity "top" is undefined Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 0 warnings Error: Peak virtual memory: 220 megabytes Error: Processing ended: Mon Feb 21 12:17:30 2011 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:01 - Altera_Forum
thanks dude
I am now running the project but when i am trying to open the files in the Nios 2 environment by creating a project and a .bsp file I get this error.
Failed to execute: ./create-this-app --no-make chmod: changing permissions of `.': Permission denied chmod: changing permissions of `./create-this-app': Permission denied can you tell me why? - Altera_Forum
I get this error when I try to create a blank project.it is not creating the .bsp file for the project and giving me this error
Try running the tools as administrator. (Right clock the icon or start menu item and choose "Run as administrator".
For some versions of the Altera tools, the installer did not set the permissions correctly on all the required files. I think they finally fixed it in 10.1. - Altera_Forum
Hey thanks it worked out ..it was a problem of the admin rights.
--- Quote Start --- I using the Altera cyclone III EPC3C120 Development board connected by HSMC interfaces to Bitec HSMC quad video and DVI daughtercards. The kit refers to AN 427 VIP sample design and asks it to download from the ALTERA site. The name of the file is vip_example_design_3c120_<version>.But I cannot find this file on the website of Altera to start with the kit. I tried to run the sample code but i got these errors. Error: Top-level design entity "top" is undefined Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 0 warnings Error: Peak virtual memory: 220 megabytes Error: Processing ended: Mon Feb 21 12:17:30 2011 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:01 --- Quote End --- i had the same error ?????? - Altera_Forum
I got it working finally...I have done it with the quartus 10.1 sp1 web edition.You will get errors initially but try to follow them and erase them.You will get it workin.Dont forget to have the admin rights.. If u need any help post here..
