17 years agoVIP: Double a video stream
Hi, I want to double a video stream (created with the clocked video in function) in order to put them out with 2 resolutions (resolution A on DVI-out A, resolution B on DVI-out B). Is th...
17 years agoYou could also create two complete data paths (two clocked inputs) and feed them both with the video input. You'll have to see what gives you the lowest resource usage.
Jake
