15 years agoVIP core questions
I' ve been using the VIP core for some time now, but am still having problems with a few aspect of the design. The project in question mixes two input channels, with clippers and scalers and multiple...
15 years agoHi,
Although it will not matter in most cases, starting the components from the output to the input is usually a better choice. You are less likely to overflow the CVI and trigger other issues in the system if the IP blocks downstream are ready to start processing when the data arrives.
