11 years agoVIP Clocked Video Output to LVDS
Dear community, I wonder if anyone has used the Clocked Video Output from the VIP (Video IP Suite) together with an LVDS display. We think about using this IP with the ALTLVDS_TX. Unfortunately...
11 years agoI’m sorry for my late reply. As Socrates wrote it is pretty simple.
IP-Component ALTLVDS_TX Number of channels: 3 Deserialization factor: 7 Output data rate: 497 Mbps Clock frequency: 71 MHz Phase alignment of “tx in”: 0 dgrees Register “tx_in” input port using: Checked, “tx_coreclock” Use “tx_outclock” output port: Checked Outclock divide factor: 7 Phase alignment of “tx_outclock”: 0 degree A bit tricky was to assign the values in correct order, due to the fact that for most display the clock is in the “middle” of the packet. Therefore, it was necessary to rearrange the bits a little bit:wire altlvds_tx_disp_tx_in;
wire altlvds_tx_disp_tx_inclock;
wire altlvds_tx_disp_tx_out;
wire altlvds_tx_disp_tx_outclock;
assign altlvds_tx_disp_tx_inclock = vga_clk;
assign altlvds_tx_disp_tx_in = vga_r;
assign altlvds_tx_disp_tx_in = vga_g;
assign altlvds_tx_disp_tx_in = vga_b;
assign altlvds_tx_disp_tx_in = vga_hs;
assign altlvds_tx_disp_tx_in = vga_vs;
assign altlvds_tx_disp_tx_in = vid_datavalid;
assign TXCLK = altlvds_tx_disp_tx_outclock;
assign TXOUT0 = altlvds_tx_disp_tx_out;
assign TXOUT1 = altlvds_tx_disp_tx_out;
assign TXOUT2 = altlvds_tx_disp_tx_out;
altlvds_tx_disp altlvds_tx_disp_inst (
.tx_in (altlvds_tx_disp_tx_in),
.tx_inclock (altlvds_tx_disp_tx_inclock),
.tx_out (altlvds_tx_disp_tx_out),
.tx_outclock (altlvds_tx_disp_tx_outclock)
