17 years agoVIP Clocked Video Input Seperate Sync Timing Tolerance
Hello All, - I'm running analog video to a TI TVP7002, which decodes it into 24 bit digital clocked video with seperate syncs. My output is a vanilla parallel TTL interface SVGA LCD. Plan is to...
17 years agoFirst thing I'd try is signaltap and look at the vsync,hsync, and data enable. If that data enable isn't working right, the clocked video input will choke.
You could try using embedded syncs instead. Also, I would connect up to the control port on the clocked video input and see what it's claiming. Jake
