13 years agoVideostrem synchronisation
Hello, I have a Altera Cyclone III Development Board and try to synchronize some Videostreams. They are delayed horizontal and vertical. Is it possible to synchronize them onboard without using ...
13 years ago --- Quote Start --- You will not be able to tie the SOF signals with Nios. This is better done in the top-level HDL file. The SOF signals are exported by the Qsys/SOPCBuilder system. --- Quote End --- I have looked for this before, but I can't find the SOF signals, because of this I thought I have to use NIOSII. In the CVIs, the "Generate Synchronization Output" is set to "yes". In the CVOs, the "Accept Synchronization Outputs" is enabled. After set both, I have regenerated the SOPC system. But in my top.bdf I can't see any SOF out- or inputs. In SOPC.v, I have only the following in and outputs:
module CVI0_dout_arbitrator (
// inputs:
CVI0_dout_data,
CVI0_dout_endofpacket,
CVI0_dout_startofpacket,
CVI0_dout_valid,
Clipper0_din_ready_from_sa,
clk,
reset_n,
// outputs:
CVI0_dout_ready,
CVI0_dout_reset
; Thanks for help!
