13 years agoVideostrem synchronisation
Hello, I have a Altera Cyclone III Development Board and try to synchronize some Videostreams. They are delayed horizontal and vertical. Is it possible to synchronize them onboard without using ...
13 years agoHi,
Assuming I understood this correctly, the issue you are having is that the outputs from the CVOs are not synchronized. The user guide has a few sections about generator lock and aligning the CVO output to an incoming start_of_frame signal. Is it something that can be used to fix your problem? Edit: As gwall pointed out, you will also have to tie the output clock and the output SOF signal to the input clock and the input SOF signal.
