13 years agoVideostrem synchronisation
Hello, I have a Altera Cyclone III Development Board and try to synchronize some Videostreams. They are delayed horizontal and vertical. Is it possible to synchronize them onboard without using ...
13 years ago --- Quote Start --- You can synchronize all four video streams, you need a frame buffer for each input. --- Quote End --- Hello mess, I have following configuration several times in parallel: CVI - Clipper - FrameBuffer - Scaler - CVO I think the delay between the videostreams has his source at the clippers. How do you think I can synchronize the FrameBuffer? Thank you
