13 years agoVideostrem synchronisation
Hello, I have a Altera Cyclone III Development Board and try to synchronize some Videostreams. They are delayed horizontal and vertical. Is it possible to synchronize them onboard without using ...
13 years agoYou can synchronize all four video streams, you need a frame buffer for each input. This can be done internally in the FPGA if there is enough embedded memory to buffer a frame of video for each stream.
If you need to genlock the output, you'll need external devices to generate your output timing.
