16 years agoVideoprocessing problems
Hello all, i got some problems with some video and image processing moduls. the first is the scaler, here the description of the structure: i got an display with 800x480 RGB parallel ...
16 years agoYes you can scale from almost any input resolution to almost any output resolution. If you are using the nearest neighbor algorithm for the scaler, all you have to do is tell it what output resolution you want. However, the bigger question is how are you going to display this. If you are going to drive a monitor at say 800x480, you need a mixer to place your scaled video (769x433) on top of a 800x480 output.
Jake
