10 years agoVideo IP, multi-tap stream
Hi. I have a camera with CameraLink interface whose clock run at 82MHz. In the desired configuration, it should supply 10 monocrhome 8-bit pixels of a line per clock tick when the line is activ...
10 years agoHi woky.
Most of VIP modules able to process 4 pixels in parallel, so you can run second clock domain at 820/4 = 205Mhz. It is much closer to be true, but in my opinion it is still very fast for Cyclone IV. I'm using 150 Mhz for video path on Cyclone V Regards Sergey Burenkov
