17 years agoVideo Image Processing with dynamic image size
Hello I am developing a system using Video Image Processing from Altera I need to convert a RGB 4:4:4 (24 bits) video to YCbCr 4:2:2 (20 bits) To do that, I am using the following component...
16 years agoHello amos
You could do the resampling by discarding one chroma sample for each pixel. It should look like this: -- Input: -- Y1Cb1Cr1, Y2Cb2Cr2, Y3Cb3Cr3, Y4Cb4Cr4 -- Output: -- Y1Cb1, Y2Cr2, Y3Cb3, Y4Cr4 You just need to figure some way to synchronize the Cb or Cr order (you should use the sync signals for this) to ensure the resulting image is correct. Hope this helps Best regards, Thiago
