16 years agoVideo Clocked output and VGA
Hi all. I am using a DE2 , and I am trying to show RGB test pattern generator on the VGA. I am using vip to genereate the colour bars, but i have not benn able to fully understand the way VCO wo...
16 years agowell, honestly, I don't know what is a Cameralink.
As soon as you are using a DE2 and CVI, you have to connect the outputs from your ADV to your CVI (a quick search into the forum should give you lots of hints or answers about that!). I think (but still, i did not try) that CVI works fine:you have to set up the ADV to recognise your video format. You can perform that operation using opencore's I2C or even "altera audio and video config" ip. best regards Phate.
