16 years agoVideo Clocked output and VGA
Hi all. I am using a DE2 , and I am trying to show RGB test pattern generator on the VGA. I am using vip to genereate the colour bars, but i have not benn able to fully understand the way VCO wo...
16 years agoHi Phate,
Thanks a lot for the reply. Here are the parameters: Test_pattern: 640x480 8bits Parallel Progressive Framebuffer: 640x480 8bits 3 planes in Parallel Frame dropping and Frame repetition 1 non-image data packet per frame (length=10) Avalon memory-mapped interfaces: 64-32-16-32-16 SDRAM Controller: Data width 16 Chip select 1, Banks 4 Row 12, Column 8 Clocked video output should be Ok, because when I try Test_Pattern -> CVO it works. SDRAM clock is 50MHz and VGA Clock is 25MHz My system clock is 50MHZ Are there any other interesting parameter in this case? Thank you again for your help. Kind regards
