16 years agoVideo Clocked output and VGA
Hi all. I am using a DE2 , and I am trying to show RGB test pattern generator on the VGA. I am using vip to genereate the colour bars, but i have not benn able to fully understand the way VCO wo...
16 years agohem.. how many bit per color plane are you using in tp generator?
my setings are made up for 5 bit per color plane, so try to set the test pattern to generate a signal rgb 444 with 5 bits per color plane. It should work. Let me know greetings Phate
