16 years agoVideo Clocked output and VGA
Hi all. I am using a DE2 , and I am trying to show RGB test pattern generator on the VGA. I am using vip to genereate the colour bars, but i have not benn able to fully understand the way VCO wo...
16 years agoone last consideration...
96 16 48 2 11 32 are the settings for VGA @ 75hz. if you want to use THIS resolution, you should set your pixel clock for the vga @ 31.5MHz Greetings Phate :)
