16 years agoVideo Clocked output and VGA
Hi all. I am using a DE2 , and I am trying to show RGB test pattern generator on the VGA. I am using vip to genereate the colour bars, but i have not benn able to fully understand the way VCO wo...
16 years ago --- Quote Start --- for CVO which are your settings? --- Quote End --- here is my setting for cvo https://www.alteraforum.com/forum/attachment.php?attachmentid=2419 however using only patternGen & cvo i get a correct output if the color is 8bit per plane..maybe because it is not connected to SDRAM. My SDRAM chip each also has 16bits datawidth. --- Quote Start --- So, if the components for de2-70 are similar, for the frame buffer,i think that my settings could work for you. --- Quote End --- i will try your setting for framebuffer and see thanks
