16 years agoVideo Clocked output and VGA
Hi all. I am using a DE2 , and I am trying to show RGB test pattern generator on the VGA. I am using vip to genereate the colour bars, but i have not benn able to fully understand the way VCO wo...
16 years agowell,
if in your system RAM runs @100Mhz, it should be right. TESTpat-> fbuff-> CVO in order to meet bandwitdth requirements, i set 5bit per color plane (SDR sdram in DE2 has a data-bit length of 16bit. so 5bit per pixel implies 15 bits, 8 bits per pixel implies 24 bits). In your system, i'll try to use 5bit per color plane in test pattern gen. and parallel color planes. for CVO which are your settings? So, if the components for de2-70 are similar, for the frame buffer,i think that my settings could work for you.
