16 years agoVideo Clocked output and VGA
Hi all. I am using a DE2 , and I am trying to show RGB test pattern generator on the VGA. I am using vip to genereate the colour bars, but i have not benn able to fully understand the way VCO wo...
16 years ago --- Quote Start --- I've empirically found out that wit 64-32-16-32-16 bits, it seems to work properly --- Quote End --- by this do you mean avalon mm masterport width : 64bits write only master interface fifo depth : 32bits write only master interface burst target : 16bitsread only master interface fifo depth : 32bits read only master interface burst target : 16bits How about the -align read/write burst
-framedrop
-frame-repetition should i tick it? and what should be the correct packets buffered per frame & maximum packet length
