16 years agoVideo Clocked output and VGA
Hi all. I am using a DE2 , and I am trying to show RGB test pattern generator on the VGA. I am using vip to genereate the colour bars, but i have not benn able to fully understand the way VCO wo...
16 years ago --- Quote Start --- Another consideration about your project: what reolution do you wanto to achieve as output VGA? you should configure clovked video output with correct timings and pixel clocks in order to work properly, and i Think that @ 60Hz 640*480 27Mhz is not the correct pixel clock... --- Quote End --- yep im also using vga 640x480..sorry but in the previous post i didnt rename the clock but the input is actually 25MHz generated from PLL outside sopc.
