16 years agoVideo Clocked output and VGA
Hi all. I am using a DE2 , and I am trying to show RGB test pattern generator on the VGA. I am using vip to genereate the colour bars, but i have not benn able to fully understand the way VCO wo...
16 years agowell, I think I've understand what's the problem.
I think clok settings i made are correct, but they are correct for video streams with the same frame input/output rate. pal is 50 (760*288) frame/second, so (after clipping the imageas 640*240) the deinterlacer would output one frame for each field, so i will obtain 50 (640*480) frames as output. But VGA output I need is 60hz, it means that i need 10 frame second. And I suppose I have no other choice to use the Nios to enable the frame rate conversion. Isn't it? once last consideration: if i use NTSC as input, my system should work properly. Am I right? RA2M, thanks a lot for you help.
