16 years agoVideo Clocked output and VGA
Hi all. I am using a DE2 , and I am trying to show RGB test pattern generator on the VGA. I am using vip to genereate the colour bars, but i have not benn able to fully understand the way VCO wo...
16 years agoHi again,
I had difficulty to understand exactly what you have done especially the explanations about clocks. But I can recommend you that I use the Frame buffer with a different clocks for memory and video stream (the clock of all VIP components), you can this by configuring the FB to "use separate clocks for avalon-MM master interface". BR, Reuven
