16 years agoVideo Clocked output and VGA
Hi all. I am using a DE2 , and I am trying to show RGB test pattern generator on the VGA. I am using vip to genereate the colour bars, but i have not benn able to fully understand the way VCO wo...
16 years agoThanks for your answer.
I've managed to use text pattern and clocked output, no i can display color bars both in 1024*768 and 640*480. Right now, I am trying to use the frame buffer between the test pattern generator and the clocked video output, using the sdram to store pixels. I am not sure on wich clock should I use. Now, I am in trouble with the frame buffer and clocks... I am using (in 640*480) 31.5 MHz as pixel video clock, 100 MHz as test video, clocked output and frame buffer clock,finally, a 100Mhz with a -3ns delay for the SDRAM, but the system does not work. I have no DDR2 on the DE2 board, but I think that it shouldn't be necessary in order to use the FB with a 640*480 image. Any hint?
