Video and Image Processing Suite - can't fit design / can't read "fifo_type": no such variable
HI,
May I know do you able to isolate which VIP IP solution and which parameter setting in the IP is causing fitter error here ?
Also can you shared with me both your fitter passed and fitter failed Quartus design QAR file so that I can duplicate failure in house and debug them ?
dlim
I assume that the clocked video output ip core cause the problem.
I prepared 2 projects, one works fine. the other will fail during fitting.
If you remove the "alt_vip_common_fifo.sdc" file in "db\ip\TPG\submodules\modules\alt_vip_common_fifo\src_hdl" before fitting the failing one should also work.
Both projects are basically the same. There is one Platform Designer subsystem "TPG" with just a Testpattern Generator and an Clocked Video Output and a second subsystem for video processig with a CVI - Clipper - Framebuffer -SDRAM Controller and CVO.
If you include the Video pipline the project will compile fine , if you comment it out it will fail during fitting.
With best regards
Sebastian Schmitz
