15 years agoVHDL output given when Verilog requested
Hi I'm currently going through the motions of getting a DDR3 controller for the Arria II GX development board. I'm using Quartus 11.0 and I've used the MegaWizard thing to generate the RTL...
15 years agoThe primary interfaced module should be Verilog, if requested, but it's only a wrapper. The IP core consists of a number of files, that may be either Verilog or VHDL, depending on the respective Altera Megafunctions.
For a functional simulation, you need to use special simulation files that are replacing the encrypted part of the IP core.
