16 years agoverilog- parameterized mux
For the life of me I cannot figure out how to generate a parameterized mux in verilog... I understand how to generate, say, a 4:1 MUX of "N" bits wide... But I am trying to generate an N:1 mux...
16 years ago1 - That first "+" sign in the array declaration is a typo. See I told you there might be errors.
:). 2 - The second "+:" sign in the "assign" statement is legitimate and is called a "Variable Vector Part Select" operator. For example, a statement like: assign data1 = data[8+:8] is equivalent to: assign data1 = data[15:8]; Generically: assign data1 = data[x+:y] So the "+:" operator uses "x" as the starting index of the vector and uses "y" to determine how many bits of the vector to index. The "+:" operator adds "y" bits to "x" while the "-:" operand subtracts "y" bits from "x". Jake I will post some equivalent examples shortly.
