16 years agoverilog- parameterized mux
For the life of me I cannot figure out how to generate a parameterized mux in verilog... I understand how to generate, say, a 4:1 MUX of "N" bits wide... But I am trying to generate an N:1 mux...
16 years agoI hope I'm not doing your homework for you. One of the shortcomings of Verilog is the inability to generate ports. So you have to bring the input in as a bus.
I haven't compiled this so there may be errors:module mux (#parameter WIDTH = 8,
# parameter CHANNELS = 4) (
input in_bus,
input sel,
output out
genvar ig;
wire input_array ;
assign out = input_array;
generate
for(ig=0; ig<CHANNELS; ig=ig+1) begin: array_assignments
assign input_array = in_bus;
end
endgenerate
//define the clogb2 function
function integer clogb2;
input depth;
integer i,result;
begin
for (i = 0; 2 ** i < depth; i = i + 1)
result = i + 1;
clogb2 = result;
end
endfunction
endmodule
