12 years agoVEEK MT - i2c_touch_config in VHDL
Hello, I'm trying to use the i2c_touch_config IP from the VEEK MT board (http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=139&no=670&partno=4) in VHDL. It is supposed ...
12 years agoThanks for your quick response.
I added your suggestion, but it still doesn't work. I tested some things with the logic state analyzer. In the attached file you can see that it registers two touches, but none of the outputs change. TOUCH_COUNT is "11", which is an undefined state. Also TOUCH_I2C_SCL is always high, which is probably not right either.
