12 years agoUsing VIP suite for Up-Scaling.
Hello, I am using VIP suite and SDI Ip core for converting DVI video input to 3G-SDI video output for sending video to long distance (150 mtrs). For the input DVI resolution 1600X1200 @60Hz, ...
12 years agoThank you sir for replying.
But sir in my design i have no external RAM, so i am restricted to use frame buffer MegaCore function. Can you please let me know, what could be the FIFO depth which can be used in CVI(Clocked video input) and CVO(Clocked video output). design flow as below: DVI -------> CVI --------> Scalar ---------> CSC ------------>CR----------->CVO (1280X1024@60Hz (1920X1080@60Hz Pclk-108MHz) Clk-148.5MHz) Here Sir, i used Bridge Clock @148.5MHz. So sir Is there any way without using frame buffer to solve this clock timing problem, by using only FPGA(cyclone iv gx) inbuilt memory? Thank you Keshav
