10 years agoUsing UART at arbitrary BAUD Rate
I am using QSYS on the MAX10. I am interfacing to another board over an LVDS Physical Layer using a UART. The data rate is 80 MHZ. I am planning on oversampling at a clock rate 4x the data rate ie...
10 years agoI would write a custom UART for this. I seriously doubt any Altera IP would let you run that fast or with 4x oversampling unless you did some major hacking. At that point I think it's easier to start from scratch. Or find a free UART example and modify that.
