16 years agousing PCI IP Core
Dear Friends, I'm intrested to use Altera PCI IP core in one of my design. I happen to get 8 bits of PCM data(64khz) for every 125us serially which i've to pump on the PCI bus which is p...
16 years agoHi raviraj jr,
No, you don't have to use a PCI bridge IC. The PCI core itself has local bus interface for you to connect to user logic. You can write the PCM samples onto a Dual Port Ram and on the other side, read out the data in 32 bits to source the PCI core.
