16 years agousing PCI IP Core
Dear Friends, I'm intrested to use Altera PCI IP core in one of my design. I happen to get 8 bits of PCM data(64khz) for every 125us serially which i've to pump on the PCI bus which is p...
16 years agoThanks for the reply kakyeoh,
yes you are correct thats the reason why i'll buffer or store the data 32 bits and use external oscilaltor of 33 MHz to transmit on PCI. I thought of usying any local bus to PCI bridge IC. (Or) Buffer the PCM samples and configure the IP Core of Altera for the same. My question is do i still need to use PCI Bridge IC externally to FPGA or the IP Core itself is a local bus to PCI bus converter.
