16 years agousing PCI IP Core
Dear Friends, I'm intrested to use Altera PCI IP core in one of my design. I happen to get 8 bits of PCM data(64khz) for every 125us serially which i've to pump on the PCI bus which is p...
16 years agoPCI bus is running on 32 bits at 33 MHz. You might wanna consider if your PCM data at every 125 us will be too slow for the PCI bus. Furthermore, your PCM is only 8 bit.
